Page 2 of 2 1 2
#616171 04/28/03 07:38 PM
what specific model/makes of 6 x 9 will fit without drilling or cutting the hole any bigger?
98.5 CSVT
#616172 04/28/03 10:34 PM
All the speakers I've used needed new screw holes, but none needed to have the door panel cut out. I've used Sony ( ) and Rockford Fosgate ( ).
2000 Contour SE 2.5L ATX - Toreador Red 2001 VW Golf GLS 2.0L MTX - Tornado Red Buy my possessed VCR!!
#616173 04/29/03 01:29 PM
the new infinity kappa 6x9's i just bought wont fit they would need the whole to be cut bigger. so i am forced to sell.
2004 silver srt-4 with some mods(FOR SALE) ;-) 1998 t-red CSVT stock and beat up :-( 1997 z24 cavalier with some mods(FOR SALE) :-? old ride- 98 Silver CSVT with some mods ;-)
#616174 04/29/03 06:07 PM
you can use all 5x7's or all 6x8's.
You can use 6x9's but only if you modify the inside of your door...If you do, do this, make sure that the speaker excursion does not hit against any part of the door, or you will hurt the cone of the speaker and your system will sound like a$$.
Jason 00 Audi S4, 2.7 Bi-turbo quattro 01 S10 Xtreme, 4.3l 98' Contour SE with some mods 96 Cavalier (beater)
#616175 04/29/03 08:04 PM
jbl 2003 now offers some 6x8 models with ford drillings
jbl 2003 6x8
GTO8626 6"x8" (5"x7") 2-Way
pecifications MSRP US$: $119.95 Pair
Power Handling, RMS: 60 Watts
Power Handling, Peak: 180 Watts
Frequency Response (±3dB): 50Hz - 21kHz
Sensitivity: 90dB
Mounting Depth: 2-7/16"
Cut-Out Diameter: 7-3/16" x 4-15/16"
P8652
MSRP US$: $229.95 pair
Power Handling, RMS: 75 Watts
Power Handling, Peak: 210 Watts
Sensitivity: 90dB
Frequency Response (±3dB): 40Hz - 23kHz
Impedance: 4 Ohms
Computer-optimized voice-matched passive crossover-The P8652 comes equipped with an outboard crossover that has been voice-matched to ensure optimium imaging, clairty and detail.
GTO8606C
MSRP US$: $229.95 Complete System
Power Handling, RMS: 70 Watts
Frequency Response (±3dB): 55Hz - 21kHz
Sensitivity: 90dB
Mounting Depth: 2-7/16" Mid-Woofer, 1-3/16" Tweeter
Cut-Out Diameter: 7-3/16" x 4-15/16" Mid-Woofer, 1-3/4" Tweeter
Impedance: 4 Ohms
Plus One (patent pending) woofer cones - The GTO8606C's mid-woofer has a cone with more surface area than competing models of the same size. The benefits of Plus One are greater efficiency and bass output.
• Computer-optimized voice matched passive crossover - The GTO8606C feature an outboard crossovers that has been voice-matched to ensure optimum transistion from the mid-woofer to the tweeter.
• Edge-driven Kaladex tweeters - These are not commonly used w-domes, but full edge-driven domes like those found in higher quality home audio speakers. The benefits are increased power handling, reduced distortion, and increased efficiency. This technology also allows for better integration with the mid/woofer.
• I-Mount (patent no. 5,859,917) tweeter mounting system - This well thought out system allows easy and versatile installation of the tweeter in the GTO8606C component systems.
• Hi-roll rubber surrounds are used to provide excellent cone-edge suspension and damping. In addition this material will not brak down due to UV contamination or
#616176 04/30/03 04:46 AM
My Memphis 6x9's wont fit w/out cuttin the hole bigger....
Word
'99 ČoňtôúŔ SE Kenwood KDC-MPV7019 AudioBahn AW1206T Flame Q Sub AudioBahn 1300HCQ Amp Blue LED Switches and HVAC
#616177 04/30/03 05:52 AM
does anyone know what the depth measurments are, so i can check myself if a speaker will fit
96 contour Sport soon to come: Ma Audio system
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
