I tapped the block for Swazo. If you look at the face of the block that is closest to the front of the car, there is a small ford insignia cast onto the block near where it splits to the separate lower portion of the block. Right where that insignia is, there is a main oil return from the heads. If you tap in there, you can avoid many of the problems associate with tapping the pan.
Rick
