#61593 05/24/02 05:41 PM
skilled Offline OP
Looks like there are several off these running around out there but... My 95 Contour is stalling when rolling down to a stop. It starts up fine in the morning - but when you pull to a stop - the revs die down - all the way down - to nothing. Always starts right up and drives fine. Another piece to the puzzle is that if you have the AC running the revs stay up there and it doesn't stall.... Any tips/ideas? Is my ECM freaking out or do I need some FI cleaner?
#61594 05/24/02 05:47 PM
Plug wires are bad....
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
#61595 05/24/02 09:43 PM
skilled Offline OP
That was pretty quick - are you really sure in that one? Wouldn't I see more problems if it were the wires?
#61596 06/18/02 03:00 AM
I just posted a similar problem on my 99 4 cyl. I currently have the problem, but experienced it the first time last summer. Last summer, I replaced the fuel filter and the problem stopped immediately. With just 8,000 further miles on the car now, I wonder if I really fixed the problem last summer or if the fuel fliter got clogged again.
#61597 06/18/02 04:11 AM
Sounds like the Idle Speed Control (IAC Motor) isn't functioning properly.
Try disconnecting the battery for at least 5 minutes and then restart the car.
This will reset your computer, and it may clear the problem.
If the problem returns, then you may need a new IAC Motor.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
