Page 2 of 2 1 2
Actually it sounds like you spun a rod bearing (most likly a seconday) and the fragments got in the oil channel, blocking it, causing pressure build up and the only way the pressure could escape was through the weakest point in the engine, it just happened to be your filter(or adjacent area).....With out definate proof of htere fault i believe you might be stuck fitting the bill.
Something like this is hard to prove that it was the shops fault, check to see if the have the timming correct on the car when they changed the tensioners.
But to me it sounds like the shop being responsible and fair (surprising!). 1500 installed is not that bad for a used motor. I suggest going with a 3 liter upgrade instead.I would reconmend shop shop, but from what i hear there customer service is serverly lacking...you can find a high quality one, and get it installed all for about 2000 to 2500 dollars. (cheaper since the dealer is so willing to help you) Contact Terry haines to see if he can get you a 3 liter, or David Z off of the NECO boards, hes a great guy and knows where tog et top quality stuff.
Im sorry to be such a bringer of bad news.....I hope everyhting works out.
Roz
As I said before, this sounds like the lack of oil is directly related to this failure. The rod bearings fail and spin because of lack of oil, this allowing the piston to move too far, bam, $$$. Although $1500 installed for a used motor isn't too bad, its about $1500 more than you should pay.
Scott
Troll! '99 BMW 328i
Scott [/quote
I must concur with Scott....Altough the oil bearing problem is like the chicken and the egg (what came first) i also truly feel that both are realted...in what order i honest could not guess, becasue i have not beenfaced witht the issue, but in either case i feel oil and the brearing are the issue!!!!!
Roz
Page 2 of 2 1 2
