Bob, stop being a judgemental D i c k. No one appreciates that, and it doesn't help the forums. This guy was just asking a simple tech question, not asking to be flamed because he didn't realize his oil had dipped a little low. No need for all that useless BS. If you can't answer this cat's question then just don't post, or go rant somewhere else about "morons" as you describe. The SVT is nice car, but its just a car...people use them as transportation...not everyone has a freaky affinity to them requiring them to perform a daily one hour inspection. Jerk.
Spec 23:
I have heard of the oilpan bolts working loose causing a leak from the oil pan gasket. Also, if your positive crankase ventilation valve is not functioning, the resulting internal engine pressures could have caused a valve cover gasket to fail. Finally, Fords in general are susceptible to main bearing seal leakage as the seal wears or if too much oil is put into the motor. Every ford I've ever had has had a leaky main bearing seal after a certain mileage.
Former owner of 1999 SVT Contour #555
