Posts: 1,044 |
My car has aftermarket wheels and slightly oversize tires. ( (215x60R15) I'm noticing extra wear on the inside edge of the front tires. Is this a caster/camber problem that can't be adjusted on our cars? The tie rod ends and balljoints have been replaced and a full alignment done afterward. The rest of the front suspension seems tight. Could my wheel offset be off enough to cause this? Any other ideas?? TIA
Posts: 1,459 |
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 3,867 |
The alignment guy has to adjust toe from factory specs to account for the change in scrub radius. Wider wheels with a slight change in offset, with factory OEM toe settings, might be the problem.
Function before fashion.
'96 Contour SE
Posts: 10,015 |
Camber CAN be adjusted, look at my group buy. It will solve the inside wear problem: Camber Kit Group Buy In the long run it's cheaper to install the camber kits and save the life of your tires, than keep chewing up tires cos you camber is way off.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 3,867 |
Originally posted by Stazi the Aussie: Camber CAN be adjusted, look at my group buy. It will solve the inside wear problem: Camber Kit Group Buy
Stazi, why would his camber be off? Car is at stock ride height.
I would make sure the stock pieces are tight and properly adjusted before I started shelling out money on new parts.
'96 Contour SE
