I noticed that only one of my fans is functioning, only the right one (passenger side) seems to function. I've read several posts and correct me if I'm wrong, but aren't both supposed to be on?
Ok...now a follow-up. I've noticed that my car is indeed running hotter now...the needle now hovers around the "M" instead of the "R". I'm guessing this is due to the fan not functioning. Now...if the engine gets too hot...would this cause the A/C Compressor to turn off? I've noticed that after driving about a half hour, the A/C Compressor turns off.
I've asked this question before but I never received an answer, so here it goes. If the car is hot....lets say it's been running for 20 minutes on a warm day....with the car off.....what should the low pressure gauge read to make the A/C function properly? Is 100 PSI too high? Is 70 too low? What's happening is my A/C Compressor will blip on for a second then never come on again, so I tried adjusting the freon but I don't know the baseline for the pressure.
So what I'd like to know...is pressure cold when ambient temperature is say.....70.
Pressure when car is on but A/C off with 20 minutes of driving...
Pressure when car is off with 20 minutes of driving.
Thanks..........
