Learned patience the hard way
Posts: 2,454 |
Actually ADC all ready makes a water to air unit for their turbo kit and I make one for the vortech kits which is what Chris is running on his car and the same on mine.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 5,810 |
Originally posted by Sandman333: would it be enough to pump the water to a heat exchanger at the rear facia?
There would be no problem running the heat exchanger in the rear of the car as far as water pressure is concerned. Well almost none. I tested the system with rear mount and front mount and the front mount system has a much higher flow speed than the rear mount with the same tubing. Just friction. That increased velocity has some fringe benefits like being more efficient and quicker cooling response.
The other problem with the rear mount heat exchanger is airflow. The air coming under the car is already forced into a directional slipstream by the front air dam as it tries to force most of the air up into the radiator area. The remaining airflow under the car is small and would tend to continue in a straight line, not turn upwards and flow out the cutout of the rear facia. Maybe if you put an airdam in the back right under it, it would help. I have some doubts as to the wisdom of that move though if you like to drive at high speed.
There is one thing about all this intercooler stuff that is disturbing me. How come I am the only one to do any testing on this stuff? Search for it. The front mount resevoir, pump and heat exchanger has proven to be markedly more efficient in my testing than the rear mount stuff. The reasons I stated above plus the ones you'll find in old posts will help explain it.
See My Mods
Posts: 1,228 |
yes, I can see how front mount would be more efficient, unless you use a larger heat exchanger in the rear because of the increased room. I was thinking along the lines of ease of installation, with the small confines under the hood. An electric fan back there should take care of any airflow problems also.
And if you are taking air under the car and moving it up, through the exchanger, and then out the rear bumper facia (that mesh screen on the back of SVTs), I would think that would help with handling at high speed, creating downforce?
95 Contour SE ATX V6- SOLD
2001.5 VW Passat GLX V6 Tiptronic
2004 Honda VTX 1800N1
There are no stupid questions.
There are a LOT of inquisitive idiots.
Posts: 2,779 |
That would be considered drag...not downforce. Drag is bad, mmmkay.
I think the ease of installation would be "easier" to do what's already in use (underhood) than routing everything ALL the way back.
Posts: 1,228 |
not if you have big hands like mine. all you have to do is lay some pipe
Posts: 1,367 |
I'm just going to install an ice maker at my air intake.
Sal Khan
00 SVT - Not pretty
00 Aprilia RSV Mille - Also Loved.
http://www.thelunchjournals.com
"I just want someone I can stand once her mouth is free of obstruction."
