I've got a 1995 Contour GL, V6, AT, built in '94. On the day it turned 110,000 miles, the speedometer has started failing. Here are the symptoms:
First it started with just an audible clicking sound from the area of the speedo in the instrument cluster. It's a fast click sound like a baseball card in the spokes of a bicycle. It gets faster or slower with the speed of the car. At very slow creeping speed the clicks are slow and distinct, and at highway speeds it blurs into basically a buzz sound. The sound correlates with the speed of the car, not the engine RPMs shown on the tach. Initially this sound was the only symptom.
Then after a few dozen miles, the speedo needle itself started freaking out. The noise is now louder and the needle swings all over the place. It will swing around in roughly the direction of the correct speed but is essentially unusable for reading a true speed.
The odometers (main and trip) DO still work, as do the other gauges. I've seen no other electrical problems either. I've seen messages in the archive from people where both the speedo and odometer fail at the same time due to the VSS or cable or other electrical fault, but didn't see any reports of just the speedo failing and making this mechanical noise I'm hearing.
(Oh yeah, I'd hope not to spend very much fixing this. I hope to trade it in when my new Jaguar X-Type arrives later THIS MONTH! Really!)
Any ideas, anybody? Would be much appreciated.
