#60997 05/16/02 05:53 AM
After running the air conditioner for awhile then putting it on the FAN setting an antifreeze smell comes through the vents. Coolant level is fine, and the car never gets past the halfway mark on the gauge. Its not a strong smell, but but it definately smells like coolant. Should I worry about this?
-Ken V.
psycho_bass@hotmail.com
My Car
#60998 05/16/02 07:06 AM
leaking heater core?
-Louis
1998 Black E0 #3826, lightly modded
#60999 05/16/02 05:27 PM
There is nothing leaking inside or under the hood, thats what I thought at first too. My truck did it once, and I had a pool of the stuff in the floor on the passanger side. Everythings dry.
-Ken V.
My Car
#61000 05/16/02 06:45 PM
Might be a pinhole leak in the heater core.
Dan B.
#61001 05/16/02 06:47 PM
It doesn't take much in the system to get the coolant smell...I had a heater core on another FoMoCo product that seeped just a little bit. Didn't think it was the core though for the same reason...no puddle inside. I was wrong...
You could always run a heater core bypass if you wanted to check for sure, but if you had any seepage at all, you will smell it in the ventilation system for a while.
#61002 05/17/02 12:00 AM
Ok, guess I will get it checked out sometime. Thanks for the input guys.
-Ken V.
My Car
#61003 05/17/02 03:13 AM
I had a coolant smell inside and outside last summer. No leaks anywhere apparent. The smell went away after I replaced the pressure cap on the coolant reservoir.
Just a thought. wink
- Jim
'96 Mystique GS, Ztech - ATX,
with CD changer, Sylvania Cool Blues, sunroof, keyless entry, and 9mm blue wires
