I looked into it, but for a factory finish, you will end up replacing pretty much everything in front of your doors. Our park lamps will not line up with the Mondeo's headlamps. Their headlamps are shaped different which meand you have to use their hood, and if your using the Mondeo hood, you will need the Mondeo bumper cover and crash bar to line up with it.
You would be better off building your own. If you still want to do it, ESP Design in the UK can get you the lamps, correct pattern for the US too. They were really helpful when I was looking into doing it.
Or.... Build your own.
Clicky!
