Originally posted by skon:
What is a good plug to go with? I am thinking Autolite double platinums. Any other opinions.
Good choice. Double platinums are definitely the way to go with the V6. The Motorcraft double platinums are also a good choice.
Also do I have to have a swivel socket to get the back plugs out?
No, a plain spark plug socket (with the rubber padding in the middle) will do and is probably better (so you don't cross-thread the plugs). You will also need an extension for the socket. I believe that I used a 6".
Check the FAQ on Changing Spark Plugs for more info.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
