#608636 04/20/03 03:09 PM
2
No Pictures but I got it installed .
Truely a short throw, not just a short shifter that's hard too reach.
Felt like an M3 on first use.
Anthony B. Davis 2Deep2 Silver SVT 2002 IASCA SQ Ult Ama 601+ World Champion runner up 2002 SLAP dBQ Champion 2000 USAC SQ World Champion 2002 USACi SQ World Champion
#608637 04/20/03 05:47 PM
when I get mine do you want to help me install?
Black 98.5 SVT "Kellie" First rule of italian driving: What is behind you, DOESN'T matter
#608638 04/20/03 07:37 PM
but how is it differnt from the b&m? Is it better? I mean whats the difference (performance wise) between the two?
1998 black Contour SVT E0 -KKM Intake -B&M Short Shifter -SPARCO front strut tower bar -24mm Aussie rear sway bar
#608639 04/20/03 08:25 PM
The steeda is actually a short-throw.. the shifts are shorter... whereas the B&M is just a shorter shaft... if I wanted a smaller shifter I would just cut mine.
#608640 04/20/03 09:11 PM
had mine on for a few months now and i still love it...it is awesome.....btw what did you use for the riser plate????just curious....
new,new ride! '99 svt black/mnb '95 mustang gt sold! '98 svt #800 sold!
#608641 04/20/03 09:36 PM
2
Kevdogg,
I can help you on the install.
I know you are in the neighborhood, like 3 blocks away I think, just send me and e-mail when you are ready.
Two tricky parts are 10mm spacer and Ford's fancy cotter pin and spring.
I broke my pin and will need get a new one.
My spacer was made with a spare piece of 3/8" thick plexiglass and a jig saw. A friend of mine made the spacer plate. It's the same size as the bottom of the shifter stand with holes for the isolators and the shifter.
The trans access plate with seal is mounted to the bottom of the spacer plate and seals the hole in the floor. The isolators are mounted to the spacer plate. Remount the shifter stand and exhaust shield.
Stick in the new shifter and click on the cables and you are done.
I would say we took about an hour but this also includes redoing my custom audio install in the center console. We also did it in my friends shop which has every tool you need including air compressor at an arms reach.
#608642 04/20/03 09:41 PM
hey man don't worry about reconnecting that large spring...as it is useless...it is not necessary at all...its function is to help push the shifter towards neutral(which is bad for quick shifting)...just leave it out,it will work much better....most people that install an aftermarket shifter just leave it out....
#608643 04/20/03 09:41 PM
Ill be getting that shortly along with a DMD.. if your friend has a shop it will make my DMD install a whole lot easier.. thanks
#608644 04/20/03 11:29 PM
I used the black plastic peice as my raiserplate, only it was a little too tall and it caught on the tower in the even gears so I had to dremel it out a little, shifts nice now. only problems is I think I need a bit more grease on it, it kinda catches sometimes, but I love it. Now I'm just waiting on my brushed aluminum shiftknob to get here to match the sexy aluminum reverse lockout collar. (dont have reverse lockout hooked up, just left it on cause it looks cool lol)
2001 Mustang Bullitt Dark Highland Green #0048 Performance by Ford Racing, Bassani, SLP, H&R and etc. Former owner of a 99 Silver Frost SVT GetOnItRACING
#608645 04/20/03 11:35 PM
really???i used that piece also,and i didn't have any clearance problems....but i am glad to see that others are also doing this mod...it makes you feel like you accomplished something,because it wasn't just a simple bolt in....
