Ill just throw this out there. There is sensor that if you unpplug it will cause the fan to run when the ignition is on. It is on the thermostat housing. It is the top one in my 95 the bottom one (they look the same) actually sends the temp to the gauge. This will throw off a cel but if you really need to you can disconect it with no tools. It might help you out if your ever in a bind.
