Posts: 29 |
do all zetecs run hot?......if they do , has anybody found a way to keep the temp. down especially in summer weather & in town traffic.......I've tried just about everything from flushing the system , cleaning out rad fins , making sure fan & wp were ok.....surely it can't be good for any engine to run up that close to overheating before the fan comes on.....
Posts: 249 |
about the only idea i have would run a cooler therastat. to kick the fan in sooner. I really dont know i have try to firgure out that for awhile.
Go Army My new home for awhile.
Posts: 29 |
I put a 180 in it..........I'm about half tempted to take it out & drill a couple holes in it , but that might ( probably) cause a CEL .......as long as i'm on the highway with good air , it stays right at R-M , get in town for about 5 minutes , right up to L.......might run a cheater switch to fan relay & switch it on high as long as it's in town.....ty4 reply
Posts: 716 |
Originally posted by odell: I put a 180 in it..........I'm about half tempted to take it out & drill a couple holes in it , but that might ( probably) cause a CEL .......as long as i'm on the highway with good air , it stays right at R-M , get in town for about 5 minutes , right up to L.......might run a cheater switch to fan relay & switch it on high as long as it's in town.....ty4 reply
$hit, mine runs at, but not in, the red in town. (actually just past the "L")
95 GL MTX Zetec, Carbon Fiber hood:
*neoprene seat covers
*new SVT rear bumper
*Proud Owner of 1962 Chevy Corvette 427
Posts: 3,465 |
how old are your water pumps????
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 29 |
not sure....i've had car going on two yrs. & it's always run hot (never in the red )..i was just trying to find out if they all do that , & if not ,what others have done to correct the situation.....not crazy about changing wp & still have same situation
Posts: 3,465 |
well the setec does run hot which is normal. however if you are getting up into the L in normal it may be time for a new water pump or you could get a lower temp thermostat from ZXtuner.
aka ZetecRacing
Posts: 1,957 |
mine always runs in the middle.
NEED AN SVT REAR BUMPER!!! pm me
Posts: 29 |
I just got out Haynes manual , & it says to replace water pump requires removing timing belt..surely there has to be a better way.....
Posts: 3,465 |
Originally posted by odell: I just got out Haynes manual , & it says to replace water pump requires removing timing belt..surely there has to be a better way.....
nope
aka ZetecRacing
