Well beefier springs?!It may be harder to break on non SVT? anyway I've several questions for those have changed your springs or struts youself,how did you break the strut bolt loose?I'm using 1/2 inch wrench with no success,may be heat it up? and what size of socket I should use on the front lower arm(rear)?
Ford has recall for the front springs (from what I read on Alldata.com)but why not the rear?
BTW if anyone has spings for sale email me at Bulebird123@aol.com
Originally posted by Eli:
yes but it will ride higher - SVT is heavier 300lbs than other models, and so the springs are beefier. afaik anyway, i just read this a little while ago in the suspension forum, i think.
