Posts: 50 |
Originally posted by LoCoChick'95: Damn dude! That is some serious work done to your car. Good job! You need to post some pics.
Sure is...wasnt free either  Anyway, I will take a pic of the gauges soon!...
2003.5 MAZDASPEED Protege #1467, Ti Grey
MODS: Schroth 3pt harness, clear corners, CF hood, grill, mirrors, dash, etc. Injen CAI, Defi D Boost/OilP/AFRatio, Greddy SP2 2.5" Cat Back
Posts: 50 |
Originally posted by Midnight: is that the 2.0 or the 2.5?
GL=2.0L
I no longer own the SVT.
Posts: 50 |
Originally posted by 1fast95tour: was all that done as a result of the pump going? or was it one of those "while-im-in-there-i-might-as-well" deals?
Some of both...I think I made the mistake of going to a non ASE certified mechanic, just because he was about $700 less than Goodyear. While I certainly dont recommend him to anyone else, I did save that money in the end...he just took his sweet time with the thing.
Anyway, I was the one who noticed the missing impeller. Had I not seen it, I think he would have reassembled the motor with the bad wp, then I would have been back at square one!
Oh well, like a good friend of mine said tonight, figure out the oil burn situation, check compression, then get nitrous!!
I had a real hard time "restricting" myself with the "while I am in there" mindset (IE, esslinger perf cyl head, alum flywheel, etc, etc...), but I kept it under control, so I rewarded myself with "some" less expensive goodies: OptiTB, SPEC Stage 2 clutch, SVT/poly mounts, gutting catalytic converter, porting exh manifold, etc, etc.)
Sorry for rambling...I hope this answered your question! If not, PM me if you like...
Posts: 50 |
Also, it is blowing a moderate amount of white smoke at startup, is this normal after a complete engine overhaul? Any thoughts...? I am pretty sure it is bluish smoke, but why would I be buring oil immediately after a rebuild?
Thanks guys...
Anyone?
Also, what OIL PSI do other zetecs run at? I am anywhere from 30 (Idle) to 80PSI (Obviously only at higher RPMS)!! Is this normal??
Posts: 3,465 |
I jusat got back form alabama and my car never went past the O in Normal the whole time  and that's with the original water pump guess I can wait to change it
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by ZetecRacing: I jusat got back form alabama and my car never went past the O in Normal the whole time and that's with the original water pump guess I can wait to change it
Me too.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 50 |
Originally posted by JontourSVT: Also, what OIL PSI do Zetecs run at? I am anywhere from 30 to 80PSI. Is this normal??
Does anyone know this?...Haynes doesnt tell me...
