Posts: 5,854 |
i've heard of throwout bearings making a whining noise, but not grinding.
1999 Silver Frost SVT
#609 of 2760
Posts: 88 |
The sound is related to my foot coming off the clutch. I am not too worried at this point.
1999 Ford Contour SE 5spd 74km
Posts: 362 |
Should I be worried my car wont move anymore?
1997 T-Red Contour
V-6 MTX
It HaS BeGuN!!!!!!!!!!!
Posts: 5,854 |
Now that sounds bad. This happened to slimshady, basically his clutch disc broke off the inner disc or something. Made a bad grinding noise and then that was it, couldn't get the car into gear anymore (no clutch).
#609 of 2760
Posts: 716 |
a throut bearing is what keeps your engine from blowing when you blowout the clutch...its a saftey thing...i really dont know alot about clutches, just know what they do when they go. my friend accidently put is 200 SVT in 3rd instead of 5th @ 80 and let up on the clutch...it was ugly.
95 GL MTX Zetec, Carbon Fiber hood:
*neoprene seat covers
*new SVT rear bumper
*Proud Owner of 1962 Chevy Corvette 427
Posts: 362 |
So how do I know if it's getting worse? Is the sound going to get louder or am I going to lose the clutch like tomorrow? If thats the case should I replace the whole entire clutch assembly or is it going to be a couple of pieces?
1997 T-Red Contour
V-6 MTX
Posts: 1,660 |
Originally posted by 1fast95tour: a throut bearing is what keeps your engine from blowing when you blowout the clutch...its a saftey thing...i really dont know alot about clutches, just know what they do when they go. my friend accidently put is 200 SVT in 3rd instead of 5th @ 80 and let up on the clutch...it was ugly.
If you don't know don't open your mouth and look like a dumbass...
See How Stuff Works on clutches for a good explanation.
Scott
Troll! '99 BMW 328i
Posts: 1,044 |
With the mileage you have on the clutch and the sound mentioned, it seems like your getting clutch 'chatter' sometimes caused by worn or weak clutch hub springs. The throw-out bearings will usually make noise continuously while the clutch is presssed. Either way, these two parts are usually replaced together due to the labor involved.
Posts: 362 |
So it's pretty much get a whole new clutch assembly as soon as possible eh?
1997 T-Red Contour
V-6 MTX
Posts: 716 |
well usually you can keep it going by taking it in and having the clutch worked on. replacing the throw out bearing (about $300 including labor) is alot better than waiting till the clutch goes at which point an install could run over a grand. rplacing the trow bearing will keep it going a little longer, maybe 6 months, i would start saing up for that racing clutch if i were you...id say you only have a few weeks if you dont fix that throw out bearing.
