Installed my set of Aussie Brakes tonight and had a few problems. I have done this several times before so I knew what's involved.
ANyways on the very first brake I got the assembly apart and for some reason the Brake Piston was completely out of the sleeve so I tried to push it back in and brake fluid shot everywhere (DAMN THAT IS SOME CORROSIVE STUFF).
After about 30mins of playing I finally got the piston back in its sleeve..but only after I drained as much of the fluid as I could by lifting up the seal slightly. Well after I got everything back together and finished the other 3 (1:00am) I started the car and I had absolutely no front brakes!
I'm not sure what the problem is...maybe air in the system or maybe I damaged the piston seal. It doesn't look to be leaking around the piston seal. What else could it be and how can I make sure there is no air in the system?
If it were the Piston Seal wouldln't I at least have a bit of pedal resistance from the other brake unit?
ANyways any help would be great! I'm stuck like chuck until I get this fixed....maybe I can perform a Bleed?
Thanks,
2001.5 S4 Santorin/Silver Stock...For now!
"Absolut Rara."
"Absolut Rara."
If the piston came you, I can guarantee there is a significant amount of air in the system now. Further, without looking at it, I can't guarantee that that caliper doesn't need to be rebuilt now (new seals).
You will need to flush/bleed the system for sure. I would recommend a pressure bleed to ensure getting all the air out for sure.
Balance is the Key. rarasvt@comcast.net
Thanks for the help! I plan on doing the bleed tomorrow...hopefully this will fix it. If it does I'll be sure to try and thrash the brakes in efforts to cause a problem to occur then. I'd rather it happen when I expect it than when I don't
Thanks again!
Moderated by  Andy W._dup1
