#60516 05/10/02 05:44 PM
H
hfidel Offline OP
H
What is a DPFE, and where is it and the EGR solenoid located on the 95 V6? Thanks for the help.
1995 V6 GL 5 spd
No mods
92,000 miles, just broken in
#60517 05/10/02 06:37 PM
I have a 96 Contour SE (V6), so I believe that our cars should be the same.
DPFE=Differential Pressure Feedback EGR
EGR=Exhaust Gas Recirculation
EVR=EGR Voltage Regulator=EGR solenoid
They are all emissions related and used to recirculate exhaust back into your engine to be burned up.
All of the directions below assume that you are in front of the car facing the rear of the car.
The EVR is just to the right of the ignition coil. It is black in color on my car and has something that looks like a bottle cap on top. It is attached by two screws to the upper intake manifold.
The EGR is just behind the air intake tube (it is silver in color on my car). One side attaches to the upper intake manifold, the other side attaches to a metal pipe that runs to the back firewall.
The DPFE is below the EGR and attached to the engine. It is hard to see, but it is box shaped.
Hope this helps.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
#60518 05/10/02 06:54 PM
A little longer explaination on the DPFE/EGR locations and description:
It's a silver rectangular box (about 2"H by 3"W by 3/4"D) that mounts to the rear of the right bank (driver's side, on the head closest to the firewall). It has two rubber hoses that go to the left side of the bottom and an electrical connector on the driver's side of the box.
The EGR attaches to the manifold at the right of the throttle body. It has a silver "hat" on the top that is a vacuum diaphram inside it with one vacuum line off of the top.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#60519 05/10/02 08:20 PM
Contour DPFE=Go poop quick.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
