Posts: 208 |
Ok I know wheel weight is important, but how much of a difference does it really make? I currently have 17x7 rage 5.0's but would I notice any difference with, say oz superleggera's (6 lbs. less per wheel approx.)? I know that theoretically the handling, braking, and acceleration would be better, but would the difference be noticeable?
1998 black Contour SVT E0
-KKM Intake
-B&M Short Shifter
-SPARCO front strut tower bar
-24mm Aussie rear sway bar
Posts: 68 |
I think you should get rid of those 5.0's and give them to me!!! Anyways if you went with a lighter wheel it would kind of be like having one less person in your car. Just to estimate
Canada = little France
Posts: 9,442 |
Yeah, a 24 lb. person
Posts: 390 |
Originally posted by bk4293: Yeah, a 24 lb. person
it's all about centrifical force. More wheel weight causes longer acceleration since there is more intia for the wheel to overcome (since it weights more and starts at rest). It also causes longer braking for the exact same purpose. I would say 6lbs per tire would be more noticable than just one person...
Posts: 2,676 |
Originally posted by offroadSVT: Originally posted by bk4293: Yeah, a 24 lb. person
yeah, more like 2. I'm serious.
Posts: 68 |
Hey man I like my analogy, and the person is going to weight more then 24 lbs, or whatever that uneducated guy said
Posts: 2,382 |
Yes weight matters. Heavier, wider wheels take more power to turn than lighter narrower wheels (momentum & friction.)
"Fear is the little death."
Muadib.
Posts: 7,025 |
errr...is that a country?
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 208 |
Has anyone with superleggera's or wheels that are at least 5lbs lighter than stock (per wheel) noticed any difference in driving?
-KKM Intake
-B&M Short Shifter
Posts: 138 |
Here's a good GENERAL rule to follow....for every 1 pound of reciprocating (anything that turns)weight that is shed is like taking off 8-10 pounds of dead weight. so yes, 6 lbs per wheel, 4 wheels, 60 lbs of dead wt. per wheel (just using the 10*6 as a generalization) thats approx 240 lbs of dead weight. That is a lot of weight to get rid of. If you want looks, go w/ 18s. If you want performance, go w/ the lightest 16" you can find.
