This is neat....someone else has this prob.
OK....look under your dash on the driver side, middle console. You should see a silver vacuum solenoid (I think this is it's term). It has an arm that moves the internal vents in accordance to what your selector is on ie: max/ac, ac, panel, defrost.
You should be able to see the arm move as you hear vacuum hisses. If you see the bar move out of the solenoid and nothing is attached.....there you are. You will just need to figure out where everything is relately close so that you can pop it back on.
However, if you can turn the selector and you don't hear a hiss, two possibilites. You have not built up vacuum in that solenoid so start the car, move the selector, turn the car off. OR....no vacuum....bad
Hope this helps
Rich
