Posts: 11 |
is it hard to replace the oil line in the front of the car ? i have a 95 mercury mystique the oil line got ripped out, how hard is that to replace? thx for all your info
Posts: 1,701 |
Which oil line would you be referring to? Is this is on a 4 cylinder or V6? Are you sure its oil and not transmission fluid? What does the line go to, and come from?
Posts: 11 |
it is right under the grill and yes it is oil and it is a 4 cyclinder, it got ripped off and bent, but it didnt break....
Posts: 5,805 |
If its mtx or auto it could be the PAS cooler line...goes to a looped tube infront of the rad/condenser as...fed by two 3/8" bore tubes that have rubber pipes near the bottom rad hose...???that one??
Posts: 11 |
i think it is tranny fluid not oil fluid and i think it runs right to the tranny, but im not sure, but it is a metal tube and it got ripped out somehow before i got it, but i am pretty sure it runs into the tranny......
Posts: 5,805 |
Posts: 11 |
Posts: 154 |
Replace the cut/bent portion with a section of tubing, and use compression fittings on the ends. That works great! I did that with my high pressure power steering line at 50,000 miles, and NO leaks, even with 117,000 miles. Total cost is probably like $10-$15 dollars. I love the inexpensive diy repairs!!!
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
Posts: 5,805 |
Sounds like the trans cooler lines that go from the trans to the rad end tank,I'd get a new line to replace the one/two that are bent/damaged.If they blow you can loose the trans fluid....not nice...TH
