Posts: 70 |
had the blinkers going on 4 way flash for maybe 5 or 10 minutes --- noticed later that day or maybe the next day that the fast double click of the solenoid or perhaps i should be calling it a relay.
so - all turn signal lights work . the 4 way flashers work. the things sounds normal when either of these are activated
when none of the blinking lights are on, i hear the fast relay clicking continuously -
and have little reason to explain it except that something is not right in there !
its just a car to get from pt a to b
usually it does it nicely --AIM: chronon1
95 Tour SE, 2.5 lliter 24V DOHC V6, 5 speed manual
Posts: 131 |
what? i don't understand. when does it blink twice as fast? when you put on either of the turn signals? i'm a little confused.
Darren
'98 Mystique LS -Duratec, MTX
Nakamichi CD-40z, Knauberized, KKM tru rev intake, 9MM Motorsport Wires, SVT Springs/Struts
Posts: 667 |
Blinkers that blink twice as fast usually mean that one of them is bad (either a bulb or connection). To find out which side is bad, first turn on the left side blinkers, then the right. The side that blinks twice as fast is the bad side. Once you figure out what side is bad, turn that side on and get out of the car to check if the front and back bulbs are working.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
Posts: 2,319 |
Just to confirm; with turn signal switch in off (ie center) position you are hearing the flasher module click at double speed? If so switch is faulty.
Some members have repaired switch (presumably dirty contacts), obtained replacement from wrecker or bought new.
Here's a couple of recent threads:
turn signal switch
DIY repair
Posts: 1,631 |
Originally posted by GeoPappas: Blinkers that blink twice as fast usually mean that one of them is bad (either a bulb or connection). To find out which side is bad, first turn on the left side blinkers, then the right. The side that blinks twice as fast is the bad side. Once you figure out what side is bad, turn that side on and get out of the car to check if the front and back bulbs are working.
THANK YOU !!!!!!!!!!!!!
I was going to post today about that. I even thought about a title:
My signals are TURBOed
My right signal is clicking very FAST.
I just have one question GeoPappas:
what if go outside and BOTH bulbs are working ???
What a coincidence this post about fast blinkers, it just happened to me yesterday and I was about to post a new thread about it.
Anything is POSSIBLE... sowing the seeds of love"
Posts: 298 |
Acutally, both bulbs COULD be working, but that does not mean one of them is not bad. Remove each blinking blub (one at a time) and replace with a good bulb, retest and when the blinking returns to normal you have found the culprit.
Bruce O
98.5 SE Sport MTX, KKM, SVT exhaust
85 Z51 Vette stroker (just in case)
Never forgetting the "Old Fart" Ray
Posts: 1,631 |
Originally posted by GeoPappas: To find out which side is bad, first turn on the left side blinkers, then the right. The side that blinks twice as fast is the bad side. Once you figure out what side is bad, turn that side on and get out of the car to check if the front and back bulbs are working.
I went outside and tested.
You were right.
My right rear bulb went bad.
Here is a note for all with turboed signals:
Check your BULBS !!!!
