Posts: 16 |
Hi. Just noticed now that the clock is not illuminated. The clock seems to be working and I can set and change the time, however, just is not illuminated. The entire dashboard lights up when the headlight switch is turned on. Is it a simple burnt out fuse? Any assistance would be appreciated. Thanks.
Posts: 1,861 |
It is probably a burned out bulb. The bulb is easy to change once you have the clock out. If I recall correctly you must remove the dash bezel to get to the clock on your Mystique.
The bulb with it's holder just twists into the back of the clock. Don't forget to transfer the green colored sleeve to the new bulb. The bulb is an usual size. I have not found a source for the bulb other than the dealer. It runs about $4.00 to $6.00.
Jim Johnson 98 SVT
Posts: 1,040 |
Big Jim's advice and recollection are right on. I replaced in both cars within a week of each other, the Mystique being more time consuming because of the bezel. See below.
Edit @ 7:00am: Following assumes tilt. To remove bezel (instrument panel finish panel) Ford manual says disconnect ground/remove panel/release clock clips/remove clock.
My experience. Gently pry out 3 retaining screw covers/remove screws including 3 above guages/wiggle panel-tilt steering to remove and clock mounts become visible.
Posts: 4 |
I had the same problem with my 98.5 contour. The clock on the 'tour just pops out with a small flathead screwdriver. Ford just had to try to make it hard to replace the bulb, they soldered it to the holder and only sell the bulb/holder combo. But...you can replace it with a #74 bulb (available at any autoparts store or wal-mart). Just solder it in or I just wedged mine in and haven't had any problems.
Posts: 653 |
Originally posted by Big Jim: Don't forget to transfer the green colored sleeve to the new bulb. Weird, I have an E0 and when I called the dealer, they said that there was a change in the 98.5's, they got rid of the green sleeve. Is there a part # for the bulb with the green sleeve?? TIA, Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it. Current - 2002 Chevy Silverado Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
Posts: 164 |
You're all lucky with the Contour clocks! I've replaced my bulb twice since I've owned the car, and with the 96 Mystique you have to remove the whole instrument bezel. Fortunately they last awhile.
- Jim
'96 Mystique GS, Ztech - ATX, with CD changer, Sylvania Cool Blues, sunroof, keyless entry, and 9mm blue wires
Posts: 274 |
mine's been out since '00, i finally got my ass up and went to the local ford dealer (bison ford) and got a bulb for my '95  now i can look at it without ducking & weaving in my car in the middle of the night, trying to see what time it is
Teal|'95 'Tour GL|75k| 16V 2.0|Rebuilt ATX|
Factory Euro Mod's (Ordered in Dec '94 From Holland)-|Larger Radiator, Oil pan, Fan, Tank..little things make a difference|
Mods to Come-|Open air w/K&N filter|New Exhaust|Pre-98 Bumper|Trim Kit|Fox 2 Rims|& More..|
Posts: 16 |
I installed the bulb. Maybe I wasn't as technically or mechanically inclined as I thought I would be, because I broke the damn holders that hold the rubber piece on the dash bezel and the steering column.
Another note, is there a part number for the green sleeve for the bulb? Otherwise, I'll have to go back to the dealer and see if they can locate one for me. I couldn't get the sleeve off the old bulb and eventually tore the thing off.
Really had a crappy time putting the whole thing back again.
Posts: 1,040 |
Soory to hear you had difficuties, hope it wasn't my instructions. Can't help with part #.
Posts: 16 |
horseydug, no, your instructions were great. Had no problem taking the bezel off. Just when I tried to put it back, the tilt/steering column and the rubber piece caused the problem. And when the holder for the rubber piece broke, I had to use super glue and electrical tape to hold the rubber piece together. The bad thing is I have to take the bezel off again to put the green sleeve on the bulb.
