#60121 05/06/02 01:02 AM
DavidD Offline OP
Ok In order this is what I did...
1) Put ProGard in gas tank
2) Used foam cleaner on engine, did not cover anything
3)Checked Autolite Platinums, gap was .7!
4) regapped to spec-1.3mm
5) Changed pvc valve
6) Started engine, bad sputtering!!!
Any Help? It's a Zetec, it ran pretty good but needed cleaning , new valve and the plugs were way off.
Too much too soon?
98 SE Duratec/MTX Plain Jane (for now)
98SVT #231/6535 Stock
www.pbase.com/ddehoyos/svt
#60122 05/06/02 08:16 PM
Fuel Filter? I change that too if you haven't already.
#60123 05/06/02 08:43 PM
I would check the hoses attached to the PCV valve and make sure that they are on tight.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
#60124 05/06/02 08:52 PM
Did you check to see if you put the spark plug cables on in the right order and are they on tight?
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
#60125 05/07/02 03:07 PM
I also believe that the gap should be closer to 1.4mm than 1.3mm.
1.3mm=0.051"
1.4mm=0.055"
Automatic
75,000 miles
#60126 05/08/02 11:05 AM
H
H
I would think foam was the culprit, next time cover the ignition coil and wires. Presumably problem disappeared as engine dried out.
Re spark plug gap: 1mm = 40 thou
Zetec 1.2-1.3mm, 48-52thou
v6 1.3-1.4mm, 52-56thou
err on high end of range.
stock CD on LS, cass on LX
4 wheel discs on LX only
#60127 05/08/02 11:12 AM
Sorry for the mixup. I was unaware that the gaps differed between the engines.
Automatic
75,000 miles
#60128 05/08/02 01:55 PM
DavidD Offline OP
As it turns out, the right plug wire was not seated properly. It just wouldn't "snap". So I crimped the end a little bit and wala.
The fuel filter was changed around 3000 miles ago.
After all is said and done, it runs much better. Thanks for all the suggestions.
I am planning more work for the car. She runs like a sewing machine.
Thanks
