Posts: 88 |
Hey! Can anyone think of a way to dim the indicator light (other than unplugging it.) Those people at Ford never figured that someone might be driving in fog at night, the glare of the light off the drivers window is terrible.
Daniel
1999 Ford Contour SE 5spd 74km
Posts: 3,335 |
What bulb does it take? There might be a smaller, similar type bulb that you could use. I would look, but I dont have a fog switch.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 9,442 |
Buy one of those bulb cover condem looking thingys. That should do the trick.
Posts: 4,294 |
BUY LEDS FROM MY GROUP BUY, THEN INSTALL THEM WITH A 500 OHM RESISTOR, IT WILL DIM IT A LOT, VERY HANDY. MINE WAS VERY BRIGHT, AND MUCH BRIGHTER WITH TWO LEDS (USUALLY YOU INSTALL 1 LED) ANYWAYS, I PUT IN A 500, AND IT DIMMED IT A BUNCH, VERY HELPFUL, AND LOOKS MUCH BETTER
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
Posts: 660 |
Originally posted by auiotour: BUY LEDS FROM MY GROUP BUY, THEN INSTALL THEM WITH A 500 OHM RESISTOR, IT WILL DIM IT A LOT, VERY HANDY. MINE WAS VERY BRIGHT, AND MUCH BRIGHTER WITH TWO LEDS (USUALLY YOU INSTALL 1 LED) ANYWAYS, I PUT IN A 500, AND IT DIMMED IT A BUNCH, VERY HELPFUL, AND LOOKS MUCH BETTER
"Number A, you don't have to shout. Do you know how many internet etiquette laws you're breaking typing in all caps like that? Well, you're breaking one: Don't type in all caps." - Strong Bad
Hey Tubs, I just lost my jengajam.
Your ghetto pass has been revoked. You're no longer an honorary brother.
Posts: 1,573 |
I unplugged mine. i had the exact same problem. just gently pop the panel off, and there is one of those plastic connectors that you can just unplug. its easy to reconnect if you change your mind. I've never regretted unplugging that stupid thing.
now officially a troll, i guess. used to have a black 96 SE, until it broke down one too many times.
now I'm hunting for a motorycle.
Posts: 186 |
A wee bit of paint or liquid paper on the tip of the LED will do the trick. I used liquid paper on a high beam LED in a VW I used to own.
Is it a pain taking the instrument cluster out of the contique? If its not too much trouble I'd like to do that to my high beam and my fog indicator.
L.
Previous owner of a 99 Mystique V6 MTX Black
Current owner of a 2004 Maxima SE MTX Silver
Forsale:
Yakima roof rack. Q-towers, bars, clips, locks. Good condition.
Posts: 4,220 |
Nope, it's pretty easy taking out the cluster.
Just pop off the clock with a screwdriver and the other surrouding trim pieces and unscrew the 3 screws you uncover.
Then look right above the cluster, and there's 2 more screws holding the main dash panel in place. Getting those out (and back in) was, for me, the most difficult part by far. They're way up embedded in the panel and impossible to see. A small phillips screwdriver and a lot of patience will get them out.
Lower the steering column and slide out the panel. You'll then see the cluster all by itself in the dash held in place by 5 screws -- 3 in the bottom, 2 in the top. Unscrew those.
Slide out the cluster, reach behind it and unplug the two plugs in the back, then pull it all the way out. You then have full access to all the bulbs.
Total time, maybe 15 minutes. You could take it out, replace the bulbs, test them, and replace the panel inside your lunch break, easy.
And you only need 2 tools. A small Phillips-head for all the screws and a flat-head screwdriver to pop off the trim pieces and aid in unplugging the plugs behind the cluster.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
