i got my superchip about a month ago and i cant get it to work at all. I've cleaned it and everything but when i install it the car wont start. I've cleaning it and brushing everything over and over and still nothing.
Can someone give me some advice or someone her in KC could you help me install it if it's not a problem.
thanks in advance
PROD # 1337. SHO Y-PIPE. FLOWMASTER MUFFLERS. magnacore plugs superchip
what year. some computers require soldering a jumper inside.
E0 SVT, lightly modded
its a 98 svt with y pipe flowmaster mufflers and magnacore plug wires.
if you're sure you've cleaned it properly, KKM is in KC and they carry chips. They might be able to help you out. http://www.kustomz.com
Thanks i'll check them out.
If not, are you positive of your ECU code? I bought the diablo chip for my regular duratec... Come to find out it was re-flashed to a different ECU code, and it wouldnt start...
1998 Contour SVT Dual-Honed UIM, 170k miles & 2000 Cougar MTX with: 99 SVT Engine, CA-KKM Intake, T.E.H. and polished UIM, High-Flow Cat, Quaife, Pro Flow 75mm, Superchip, TruBendz dual Borla, WR-SS Headers, Fidanza, Grizzly Street, Roush & KYB...
the code on the ecu and the chip both match.
how do you find out if it was reflashed i bought it used off a guy in stlouis.
Moderated by  Eric L_dup1, louisw_dup1
