Posts: 1,603 |
Originally posted by Lee: Rebuilds typically don't change the valve bodies or the actually gearings just the wear parts like the clutches and the torque convertor. Unless there is a more serious problem. Alot of issues with the CD4E are in the valve body and cylinders. Also the 96+ have a VSS with a gear that goes into the tranny. I'm willing to bet that even though it's done by wire that it is using the same spot as the Speedometer cable. I just don't see Ford changing the casting for just that.
In the case of the CD4E, a rebuild includes REPLACING the valve body. The Aluminum cast of the original valve body is so soft that the valve bores wear prematurely.
There are differences in the CD4E Solenoid resistances and the PCM in the 95 model year, that weren't carried forward into the 96 and later years. There were also many revisions made to the CD4E after the 95 model year.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 21,653 |
get a completely rebuilt CD4E with all updated parts. Make sure you get the 95 solenoid or whatever it is roadrunner mentioned. I believe the newer can work, but fails quickly on a 95. Add the filtertek (i think?) inline filter and a tranny cooler, and use synthetic ATX fluid, it'll last a lifetime then. A shift kit and/or chip wouldn't hurt either. I realise this car isn't your show car, but it doesn't hurt to have it be nice and last as well.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,603 |
Originally posted by Kremithefrog: Add the filtertek (i think?) inline filter and a tranny cooler, and use synthetic ATX fluid, it'll last a lifetime then.
Filtertek manufacturers the latest sump filter for the CD4E transmission. It is designed in such a way, so that if the filter/screen were to be blocked with large debris, it would not impede the flow of oil from the sump to the transmission pump. The previous sump filter did not have this ability and oil starvation was the cause of the transmission to fail, after very long internvals of very high speed driving.
Pete...
DOB 10/31/2003
DOP 1/2/2004
Posts: 10 |
I have a 95 v6. It sound like if you have a 95 you would have to spend 2500 for a good rebuild or junk the car.I don't think this car will run without a speedometer cable. I think I'll just burn this piece of junk.
Posts: 3,732 |
Originally posted by seabrook: I have a 95 v6. It sound like if you have a 95 you would have to spend 2500 for a good rebuild or junk the car.I don't think this car will run without a speedometer cable. I think I'll just burn this piece of junk.
can i have it?
Russell
Oval Port 3L Nearly Done
Posts: 10 |
No I'd rather burn it in a ford parking lot. I live in SC I might give it away before its over. I can't believe u people like these cars.
