I did a search and found out that this is a fairly common problem. Why does it happen? Pulling the swaybar sounds like a kind of kludgy fix that won't last very long.
Does the swaybar normally move from side to side during normal operation? Are my old bushings binding up and not letting it return to the proper position?
BTW, my car has 93k miles on it.
Thanks for any help! smile
96 Contour GL (2.0L Zetec, ATX)
Sony CDX-C780 HU, Sony CDX-805 10 disc Changer, Sony XDP-210EQ, RF Punch 100.2 Amp, RF Punch 240.4 Amp, Dual 12'' Punch subs, Four Infinity Kappa 693.3i 6x9's, Optima Yellow Top
CTA Intake, Hood Struts, EL Ford Logo, Hi Beam/Low Beam Mod, Blue LEDs in door handles and footwells
there is an updated swaybar that will correct this. it has stops on both ends to prevent the bar from moving side to side.
1)Disconnect the end links 2)center the bar so it clears frame etc 3)Get some hose the same ID as the bar,cut it 1" long and split it along its length 4)Slip over the bar and slide up to the bushes each side 5)Clamp it to the bar with a hose clip...done, you have stopped the sideways movement ... wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Terry, that's a plan! Can I elect you for president or something? LOL!
If you like... wink ,this way it saves the cost of buying the later bar and does the same job..regards TH
V6 MTX
