Posts: 2,319 |
Idea is to stick head in and listen in order to better determine noise source, although sitting in back seat might also work. Didn't realize it's intermittent, which makes it more difficult to find.
Sorry, nothing coming to mind at the moment. Hopefully someone else will have some ideas to share.
Posts: 3,627 |
my fuel pump makes a whining noise... anybody know what thats about?
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
Posts: 2,807 |
Maybe it is on hte driver side, it sounds as though it is on the passenger side. I will try to locate it more accurately next time it happens. Would there be anything else located in that region of the car that could possibly cause this noise? It must be the pump.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 644 |
Originally posted by SVTCANUK: Maybe it is on hte driver side, it sounds as though it is on the passenger side. I will try to locate it more accurately next time it happens. Would there be anything else located in that region of the car that could possibly cause this noise? It must be the pump.
What about the exhaust? Small hole "clicking" a little when cold? Is the single exhaust on the driver or passenger side? Hmmmm...
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 2,807 |
Originally posted by delmar: Originally posted by SVTCANUK: Maybe it is on hte driver side, it sounds as though it is on the passenger side. I will try to locate it more accurately next time it happens. Would there be anything else located in that region of the car that could possibly cause this noise? It must be the pump.
Driver Side.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 2,807 |
OK the noise is definitely coming from the pasenger side rear of he car. Either under the seat or trunk, it's hard to tell which, but definitely on the passenger side, any new ideas???
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 2,319 |
Other than power antenna, which you do not have, there is no electrical device on that side of car. Only thing I can think of would be a noise generated by fuel vapour recovery system or filler tube. Possibly caused by pressure changes within the tank as the fuel system reaches operating status. There is a check valve located at top of tank, pass side that could perhaps chatter during this period.
Long shot, but all I can offer.
Posts: 2,807 |
Thanks for the help, I may have to drive the car without the rear seat to further pinpoint the source of the noise. Something I have failed to mention ![](/ubbthreads/images/graemlins/crazy.gif) is that the car does not idle properly when this happens and on occasion will stall, this is what draws me to the conclusion of the fuel pump. I hate intermitant problems, they should be outlawed ![](/ubbthreads/images/graemlins/grin.gif) .
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 2,319 |
Well you could pull rear seat cushion up and loosen grommet from access hole on pass side of center hump, this would make any tank/pump noises more audible.
Posts: 2,807 |
Originally posted by horseydug: Well you could pull rear seat cushion up and loosen grommet from access hole on pass side of center hump, this would make any tank/pump noises more audible.
I'm gonna have a look under there this weekend.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
