Originally posted by Tiger561: For future reference, great tire deals can be had at tirerack.com for tires.
Ditto...
I got a pair of top-rated tires for $50 cheaper than the local NTB (National Tire & Battery). I couldn't believe that delivery was only around $14!
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
