Hi All,
My Contour has 107,560 miles on it. I had it used, so I have no ideal that the original water pump had being replaced before or not. I am now preparing myself for replacing it. Based on the Haynes manual, the water pump hiding behind the timing belt, so I need to remove the timing belt first. I am intimated to remove the timing and additional attention is needed for the cramshaft position when putting back on the belt. I replaced a water pump on a GM car before and I am handy person. My questing is how difficult it is to replace it on the contour? Is it way above my head? Can I just but dot marking on the belt and the pulley and make sure I align them when putting back on? Has anyone done this on this model before?
Thanks,
Tony Wong
6
6
If you have the V6, then here ya go.
Drain the radiator. Remove the heatshield, 3 7mm or 8mm bolts. Now the cam pulley, tension pulley and water pump are now exposed. Push down on the tension pulley, the belt is now loose. The waterpump is now ready to come out. About 8 bolts hold it in, 8mm IIRC. It should pop right off. Make sure you don't have your face right underneath it when you pull it off. I did this and ended with a mouth full of rather warm antifreeze, LMAO at my dumbass self. There is a ring of sorts that goes around the impellers that stays in the block, it just sits in there and is held in by the waterpump, make sure that that stays in there cause Ford had a reason for it being there. Make sure all the old gasket is removed.
Reverse all previously said to have a new waterpump and peace of mind.
Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it.
Current - 2002 Chevy Silverado
Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
6
6
Whoops, after I posted that, I fully read the topic of the post. All I saw was waterpump replacement and thought, I just did mine, I know what to, so I'll post a reply.
I'm stupid
Mike
I may be doing this today or tommorrow so let me get back to you with details.
I've been looking at the Ford Service CD-ROM and it isn't an easy job but it's not too hard either...from the look of it.
This is copied from the CD-ROM...I'm hoping the crankshaft tool can be borrowed from Autozone or Pepboys. Don't wanna have to buy it for this one thing...but oh well, if I do.
Water Pump - 2.0L
Special Service Tool(s)
Strap wrench
303-D055 (D85L-6000-A)
Removal
1. Note:
Install the memory saver.
Disconnect the battery ground cable.
2. Drain the cooling system. Refer to Cooling System Draining, Filling and Bleeding in this Section.
3. Remove the wheel.
µ 4. Remove the right - hand side lower splash shield.
1 Remove the bolts.
2 Remove the splash shield.
5. Lower the vehicle.
µ 6. Loosen the water pump pulley bolts.
7. Remove the accessory drive belt.For additional information, refer to «Section 303-05».
µ 8. Using the special tool, remove the crankshaft pulley.
µ 9. Remove the water pump pulley.
1 Remove the bolts.
2 Remove the pulley.
µ 10. Remove the water pump bolts.
µ 11. Note:
Water pump must be turned 180º to remove from the vehicle.
Remove the water pump.
Installation
µ 1. Install the water pump and bolts.
µ 2. Install the water pump pulley and install the pulley bolts hand tight.
µ 3. Using the special tool, install the crankshaft pulley.
4. Install the accessory drive belt.For additional information, refer to «Section 303-05».
µ 5. Tighten the water pump pulley bolts.
µ 6. Install the splash shield.
µ 7. Install the road wheel.
8. Refill the cooling system. Refer to Cooling System Draining, Filling and Bleeding in this Section.
Mike, not at all. Thanks for your input though.
SQPlus, there is no mention of removing the timing belt in the Ford's instruction. Are they saying that the pump can be slide out behind the timing belt? There are timming belt guide pulley attached to the water pump casting. By removing these two pulley, it will loosing the timing belt.
This the how my water pump looks like, if I can
successfully attach the picture.
