Mike, not at all. Thanks for your input though.
SQPlus, there is no mention of removing the timing belt in the Ford's instruction. Are they saying that the pump can be slide out behind the timing belt? There are timming belt guide pulley attached to the water pump casting. By removing these two pulley, it will loosing the timing belt.
This the how my water pump looks like, if I can
successfully attach the picture.
