#595656 04/05/03 05:10 AM
CMAC Offline OP
Has anyone changed an SE gauge pod to SVT and if so how hard was it?Also do you have to jump through hoops to get one with correct milage on the odometer or can you just order one new from Ford?
2000 Contour SE,All stock and lots a fun,But I have plans
#595657 04/05/03 05:20 AM
If you have a tach, I can guarantee it will work. I got a used one from the auto salvage yard, w/ only 1300 miles on it for $85+tax. I plugged it right in and it's been accurate ever since. It's not hard to take out. PM if you need anymore detailed instructions.
02 Nissan Altima 3.5 SE, FULLY LOADED Old car- 99 SE Sport ATX w/ SVT body kit (for sale...asking $4,200 OBO), nicely modded, high-flow exhaust y-pipe back and KKM. 95K, but 95% are interstate highway miles back and forth to college everyday.
#595658 04/05/03 05:38 AM
i have the complete gauge cluster/electronics in my car. the coolant temp and gas gauge did read backwards so i had to pull the faces and put them on my stock se gauges. The speedo did need some recalibrating but that is simple. As far as the odometer, theres some small screws on the back of the odometer that hold in a plastic piece. take those off, and roll back/forward the odometer with your finger.
#595659 04/05/03 06:44 AM
CEG road warrior
CEG road warrior
Got a SVT cluster in my 2000 Zetec. The tach didn't work though.
#595660 04/06/03 05:49 AM
Buy it from ebay, i got a 2000 gauge cluster w/out tach for 9 bucks!!!!!
'99 ČoňtôúŔ SE Kenwood KDC-MPV7019 AudioBahn AW1206T Flame Q Sub AudioBahn 1300HCQ Amp Blue LED Switches and HVAC
#595661 04/06/03 06:24 AM
9
mine went right in temp and everything was fine, only thing is make sure you a: dont hit the hazard switch while your putting it in b: best bet unplug the battery!!!! i didnt do either after a visit to ford under warranty required me pulling them out well as i was putting them in i hit the hazard switch. melted the whole back of the cluster luckily they were free
#595662 04/06/03 10:22 PM
So would this work for my Mystique too? I'm thinking it should. What is involved in this "speedo recalibrating"?
1996 MM Zetec, ATX 192000 kms...not dead, but I'm not fixing it White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
#595663 04/08/03 07:21 AM
Im telling! haha just playin..
