Page 3 of 3 1 2 3
Y
Y
Mine made it to about 130k .Its not real bad to change. unless you break a bolt off in the housing. mad
Yankeyspeed: American power and ingenuity
95 SE -Stock enough
Yeah my car has a baby seat, its still fast.
Parents - 95 Mystique (145K waterpump failure)
mine - 2000 Contour (63K orginal waterpump)
2000 Silver SE Sport V6 MTX, B&M shifter, SVT exhaust, 75K on the clock.
43K -- 1/4-th each of two blades only remains of impellor. Mexico built, true 98 (before 98.5 de-contenting).
When I get the money, putting on one of Terry's electrics, so don't have to worry about this one "Quality is Job 1" snafu.
Mike
SCCA WOR/OVR/NEOh Regions
Race Control Marshall
#53 Silver Street Touring "S" '98 Contour
GL; 2.5l-5 spd
"Koni Kit - Sport Struts w/progressive "sport" springs" from HMS!!
Custom 24-mm Rear Sway also from Terry
BAT Camber/Caster through HMS
PF Spherical Ball End Links
Bridgestone S-03's
Grizzly Clutch
lightened SVT flywheel (Thanks KnuConceptz)
DMD from incomparable Terry Haines!
K&N & Dynomax
Mintex pads
Chris Hightower Rear Strut Tower Bar
V
V
My informal CEG research indicates the average failure rate seems to be closer to 60K mi. I had planned to change mine before that but haven't gotten around to it yet (64K).
Originally posted by Phil Rohtla:
When was the switch made from the black (evil) to white (less evil) impellers? Sure hope it was before my E0 SVT was made
Phil! Change it! Actually we can do it when I'm in Ottawa sometime. Even the newer ones aren't failsafe. There's actually another part in the waterpump housing that fails almost as frequently as the impeller itself. I opened mine up one beautiful Feb day just to change the impeller as a precaution, and the piece of the housing came shooting out, requiring me to buy a new pump housing.
Black E1
N
N
I'm at 78500 miles and running the original pump...
Page 3 of 3 1 2 3
