#59190 04/24/02 03:20 PM
W
WR99SVT Offline OP
W
i have a recurring problem with battery post corrosion. i will clean it off and a few weeks later it will be back, bad. any idea what could be causing this? battery bad? overcharging? no idea here, clue me in. thanks
The metric system is the tool of the devil! - Grandpa Simpson
1999 T-Red SVT
#89 of 2760
Bullitt Fuel Door
Aussie Grills
B&M Short Shifter
MORE TO COME THIS SUMMER?
#59191 04/24/02 03:35 PM
Your battery is probably getting old. The seal between the post and case is leaking, causing acid to escape and corrode the post.
Dan B.
#59192 04/24/02 03:49 PM
it is normal for the posts to corrode. you need to clean up the terminals real good and cover them in grease. that way they won't corrode.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
#59193 04/24/02 06:08 PM
I get a powdery blue crap on mine (+ terminal), anyone else get that ?
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
#59194 04/24/02 06:12 PM
that's corrosion. clean it up with a wire brush and coat it with grease.
-Dan
#59195 04/24/02 06:37 PM
My OE battery did that on the + terminal. Never could totally prevent it.
Optima orange top took care of the problem.
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
#59196 04/24/02 07:05 PM
It has a leak of some sort! A Battery should not have any excessive corosion on it. See if the battery post itself is loose. It's probably leaking from around it.
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
