#59064 04/23/02 01:04 PM
Mykul Offline OP
I have a '96 four banger and it is suffering some serious idle problems. It almost dies when i come to a stop and I have to put it in neutral to keep it from dying at a stop. I have replaced the fuel filter, the PCV valve, air filter and cleaned the small filter located in the air intake box. The CEL was coming on before I replaced everything but after I reset the computer the CEL has not come back on. Could it be the IAC? Would cleaning it help or is it best just to replace it?
Thanks,
Mykul
#59065 04/23/02 04:24 PM
Did you check your spark plugs?
#59066 04/23/02 04:36 PM
Just had the same cr@p happen to my 95. Sounds all too familiar (almost dying when coming to a stop, rough idle). Took it to the dealer and they replaced the MAF sensor, O2 sensor, cleaned EGR tubes, carbon flush. Let me ask you this. Have you had the catalytic converter recall done? If so, this may contribute to the problem. It did in my case. So, $900 later eek my car runs like a top again. Good luck!
metallic willow green 95 contour V6 ATX.
K&N Air Filter
Hoodliner removed
Remove Resonator soon.
Dynomax/Magnaflow Muffler soon.
#59067 04/23/02 04:40 PM
MFE Offline
Clean the MAF element!!! Works like magic for the cost of a can of carb cleaner and a can of brake cleaner. Shoot it clean with carb cleaner first, then shoot it with brake cleaner to remove all traces of carb cleaner. Try it before you spend a dime replacing ANYTHING.
Pacific Green '96 Contour LX V6, loaded
'98 Grand Prix GTP 14.88/91 bone stock, awaiting new times from 3.4 pulley, CAI, U-bend removal but it's creeping up on the...
Calypso Green '92 Mustang LX coupe, 13.56/101
3-time local class champion autocrosser
Racing school whore
#59068 04/23/02 07:19 PM
N
N
Mines had the same problems. I had a full tune up (new Motorcraft spark plugs, wires, and fuel filter) done by a mechanic at a quick oil change place. The parts came in a Motorcraft tune-up kit. No more rough idle or engine dying at idling after that.
#59069 04/23/02 09:26 PM
Mykul Offline OP
How do I clean the MAF element?
#59070 04/24/02 03:39 PM
Mykul Offline OP
I cleaned the MAF and I still have the same problem. Though now when I start the engine it revs really high then slowly comes back to a normal idle speed.
#59071 04/24/02 04:04 PM
when you put it in neutral and it regains it's idle...then you put it back into drive, does it stumble then and want to stall?
if so, you probably have a bad egr valve.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
#59072 04/24/02 09:12 PM
Mykul Offline OP
Yeah, it does run fine in neutral and then rough in drive. The check engine light came on about the same time this started happening. Time to pull some codes I guess.
#59073 04/24/02 09:19 PM
Mykul Offline OP
How much does a egr valve cost btw?
