#59056 04/23/02 08:07 AM
my car has been actin really weird when i turn the ignition. Some times it will struggle to turn on, like a 2sec delay while i'm turnin the ignition, and other times, it will start just fine. I don't think it's the starter but it could be the solenoid or a faulty fuse, maybe something electrical like the main relay. has anyone had this problem. please help, I don't want my car to die on me. Thanx
98.5 E1 SvT
18" RACING HART C2
H&R SPRINGS
Brembo Cross Drilled Rotors
KVR CARBON FIBER pads
BORLA CAT BACK EXHAUST
SHO Y PIPE
B&M SHORT THROW SHIFTER
MAGNECOR KV85 PLUGS
Clutch Masters Stage II Clutch
KKM INDUCTION
OMP FRONT UPPER STRUT
BAT LOWER STRUT
SHO TRUNK TIE
MOMO SHIFT KNOB, PEDALS,
LEATHER BOOT
PIAA SUPER WHITES
http://www.members.aol.com/SvTurbo911/svt3.jpg
http://www.members.aol.com/SvTurbo911/svt2.jpg
http://www.members.aol.com/SvTurbo911/svt1.jpg
#59057 04/23/02 12:55 PM
Might want to check, clean, and tighten the battery terminals as a precaution. You can get the battery and charging system tested for free at autozone type car part shops. Your symptoms don't fit a fuse or solenoid problem. I think the starters are generally pretty reliable on the 'tour.
Scott
#59058 04/23/02 07:44 PM
N
N
I had similiar hesitant starting and it was due to a weak battery. Have your battery and alternator checked out. If you still have your original battery, then it may be time to get a replacement. My original battery lasted about 3.5 years and my last battery about 2.5 years.
#59059 04/24/02 05:09 AM
well I just got a battery like 3 months ago so I don't think it's that. Could be the starter cause if it was the alternator, my car would startle while it the car is on. Please give me some feedback
98.5 E1 SvT
18" RACING HART C2
H&R SPRINGS
SHO Y PIPE
MAGNECOR KV85 PLUGS
KKM INDUCTION
BAT LOWER STRUT
SHO TRUNK TIE
LEATHER BOOT
PIAA SUPER WHITES
