I dont know if this is common of not. I have a 1996 Contour 4 cyl. When I have the heat off as in the switch to the off position the idle is fine. Smooth and vibration free. As soon as I turn the heat on floor/def, defrost, or any other it will idle fine but every few seconds I hear a click in the engine compartment; the engin boggs down (steering wheel/dash vibrates a bit) then the engine revs up a bit then goes back down to an idle. This does this constantly every few senconds while the heat switch is on. I talked to a ford dealer and he said it sounded like the A/C compressor is turning on and off. It does this when the A/C is on also. I cannot figure it out. No CEL comes on. I dont see a problem with it other then it is annoying while the car is idling it revs up every few seconds constantly. It is probobly not good for the motor either. Could this be a faulty switch? Faulty relay? Normal on these cars? If it is the A/C why is it turning on with the heat? I thought I would start here with others whom may have the same issue.
Any help is greatly appriciated.
Travis
