Redneck Troll
Redneck Troll
Posts: 2,621 |
Here are some of the part numbers for aftermarket and/or Ford OEM 3L parts. If anyone has any corrections or things to add to this post, please do so. Please keep other comments and/or questions in other threads please so that this post is just as informational as it can be. If you have part numbers, please post them here, then PM me and I'll add them to the list in the first post (this one) so we can keep scanning for part numbers to a minimum. 3L related parts only.
Note: Prices listed are what I have paid in the past and may not be current with today's pricing at your local parts store.
Seals and gaskets:
- Fel-Pro Part# 70149 EGR gasket
- Fel-Pro Part# ES72159 Head bolt set,2.5L 2 req. $16.92ea
- Fel-Pro Part# TCS45966 Camshaft rear seal gasket set $6.95
- Fel-Pro Part# CS9038 Gasket set, lower conversional $72
- Fel-Pro Part# TCS45967 Crankshaft front seal $14.55
- Fel-Pro Part# HS9038PT Head set , conversional $231.15 <--- Includes 2.5L head gaskets that you don't need.
- Fel-Pro Part# MS95726 Intake manifold gasket set $30.15
- Fel-Pro Part# OS30675R Oil pan set $35.27
- Fel-Pro Part# VS50462 Valve cover set $32.59
- BCA part# 3909 Crankshaft oil seal $13.32
- BCA part# 5277 Crankshaft oil seal (teflon) $16.76
- BCA part# 99363 Crankshaft oil seal (redi-sleeve) $33.50
- BCA part# 88187 Harmonic balancer Sleeve $4.18
- BCA part# 482041N Oil seal, front timing cover $7.67
- BCA part# 99187 Oil seal, front timing cover (redi-sleeve) $22.58
- Fel-Pro Part# 61006 SE TB gasket $1.59
- Spectra Premium # 1719 non-SVT radiator $138.41
Clevite 77 bearings:
- CB-1772P Rod bearing, available in standard, -.25MM, -.50MM, and -.75MM.
- MS-2207 Mains (not yet available)
Federal Mogul:
- 7262M- Standard Grade Main bearings (also available in non standard grade)
- 6-4395A- standard grade rod bearings (also available in non standard grade)
Ford part numbers:
- Lower cylinder block retaining bolts: F5RZ-6345-C need 4
- F5RZ-6345-D need 8
- F5RZ-6345-E need 5
- F6DZ-6345-CA need 5
- Connecting rod bolts: F3LY-6214-A need 12
- Piston rings: YF1Z6148BA 30.03 (does 2 pistons)
- VALVE-EXHAUST: F6DZ6505A
- VALVE-INTAKE: F6DZ6507A
- ST220 VALVE-SPRING: 2S7Z-6513-AA
- Motor mount/Powersteering bracket parts (needed for mid '98 and previous years to fit to the 3L block):
Bracket: 1S7Z3A732AA $32.72 LIST
Long Bolts: W704693S309 $5.22/EA. LIST
Short Bolts: W704694S309 $3.53/EA. LIST
ARP bolts:
- ARP Head Studs 253-4701
- ARP Main stud kit 253-5402
http://www.bnmotorsports.com
Posts: 1,379 |
A moderator should stick this to the top.
~~~~~~Mike~~~~~~
Black 2006 VW Rabbit
Silver 2000 Contour SVT - SOLD
~~~~ The Car~~~~~
Posts: 1,210 |
VALVE-EXHAUST F6DZ6505A VALVE-INTAKE F6DZ6507A ST220 VALVE-SPRING 2S7Z-6513-AA Motor mount/Powersteering bracket: Bracket: 1S7Z3A732AA $32.72 LIST Long Bolts: W704694S309 $5.22/EA. LIST Short Bolts: W704693S309 $3.53/EA. LIST ARP Head Studs 253-4701 ARP Main stud kit 253-5402 Just a few which were recently posted
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Redneck Troll
Redneck Troll
Posts: 2,621 |
Originally posted by 96BlackSE: VALVE-EXHAUST F6DZ6505A VALVE-INTAKE F6DZ6507A ST220 VALVE-SPRING 2S7Z-6513-AA
Which year bracket is that? It was mid '98+, right??? Let me know and I'll edit my top post to reflect it.
Posts: 1,210 |
oops missed this post hehe it says they changed mid98+ in the thread
Watch me go
Redneck Troll
Redneck Troll
Posts: 2,621 |
Thanks.  Anyone else??? I know there's a lot more parts out there. Let's get some more part numbers here!
Posts: 451 |
fel-pro EGR gasket is 70149
95 SE ATX
Electric red
mucho mods
2005 Scion xB
Black Sand Pearl
tinted windows
red leather steering wheel
US Army Mechanic
Posts: 54 |
are these allthe parts neccessary to upgrade to a 3.0L? just out of curiousity, what are the horsepower/torque/acceleration etc. advantages to a 3.0L vs the 2.5? also
what if i wanted to put a V8 in my contour.. are there any smallblocks that would fit?
Thanx!!
Jeremy AKA Jai
**'95 SE Contour / Midnight Purple (R.I.P)**
Hopefully soon to own a candy red 1992 Caddilac STS ~ w00t w00t!
Redneck Troll
Redneck Troll
Posts: 2,621 |
Jai, please ask your questions in a new 3L forum thread of your own after searching. That way this thread can remain a sticky full of part numbers only and not generally easy questions to answer. After searching and/or posting your questions, if you still have more questions, please feel free to PM or email me or any one of the more seasoned members.
Posts: 3,732 |
how much do these usually cost?
ARP bolts:
Russell
Oval Port 3L Nearly Done
