#58704 04/18/02 01:22 AM
SVTee Offline OP
Tonight when I got home, I hit the switch to close the tilted sunroof. Heard a funny noise from the switch area...and nothing. Won't close or slide. Fuse? Motor? Help.
2001 SVT
#58705 04/18/02 02:03 AM
H
H
I've got a similar problem; out of curiosity, was it hot (weather-wise) when you had this happen? I've heard that it might have something to do with a plastic gear which meshes with a metal gear that closes the roof. When it gets hot, the gear gets soft and won't turn, or something like that.
When the temp outside cools down, it closes no problem.
"Even a clock that doesn't work is right twice a day"
Hemlock54@hotmail.com
#58706 04/18/02 02:14 AM
SVTee Offline OP
Hemlock: Yea it was hot today in NC, 90 degrees. I'll try it tonight. This is the first time its happened.
#58707 04/18/02 04:34 PM
H
H
Good luck; the s**t thing about my situation was that when I took it to the dealer, they couldn't duplicate the problem until my 3rd pass to them. They had to take the whole console apart to get to the gear and there isn't a metal gear that can be replaced for it, unfortunately.
#58708 04/18/02 05:21 PM
E
E
my sunroof motor blew itself apart last weekend!
worked fine all day, the whe i went to close it..nada.
took the console apart and found the gearbox in pieces. put it back together and was able to close it. luckily its covered under warranty.
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent*
Please call...
1-800-FOR-ELKY
All proceeds go towards saving CEG
#58709 04/19/02 01:04 AM
hey i just had the same problem the motor burns out if your still under warrenty just go to the dealer and they will fix it..
00 svt contour
black
B&M shifter
#58710 04/19/02 01:05 AM
00 svt contour
black
B&M shifter
#58711 04/19/02 01:24 AM
I had this happen once.....I shut the car off while I was closing the moonroof...........when I turned the ignition back on....it would not close. I turned off the ignition, then started the car.........then shut it off completely. When I turned the ignition back on....the moonroof closed.
I hope this helps.............
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile
Moderator of the Florida Contour Enthusiast Group
#58712 04/19/02 02:16 AM
SVTee Offline OP
Thanks guys. It closed this morning. i haven't tried to open it again with t-storms in the forecast.
I don't even really like using the sunroof much anyway. Its humid here in North Carolina.
#58713 04/19/02 02:17 AM
SVTee Offline OP
