#5862 03/20/02 03:21 AM
SVT19 Offline OP
Some guy that my friend knows thinks that his Probe GT has a Duratec Engine in it. He also thinks it's the same engine that is in a Contour SVT. I know its not the same engine that's in a SVT Contour and also last time I checked it's the same engine that is in a Mazda MX6. Can someone tell me if I'm right or wrong
'98 E0 Black SVT Contour
BAT Air Inlet Pipe w/ITG Filter
#5863 03/20/02 03:26 AM
You may have better luck asking Duratec questions here,
http://www.contour.org/forums/ultimatebb.php?ubb=forum;f=49
Sorry, I don't know anything about the Duratec.
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
#5864 03/20/02 03:28 AM
Master P
Master P
Completely different engines in the Probe and Contour.
#5865 03/20/02 03:29 AM
I believe you are correct in that the Probe GT & MX6 use the same engine. They both had a 165hp 2.5L V6.
Tom
98 LX
#5866 03/20/02 04:15 AM
Completely different engines!
2000 SVT #674 - Check it out!
#5867 03/20/02 04:30 AM
6
6
Demon, is it true the jag x-type nd s-type have 3L duratechs? wonder the possibilities
Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it.
Current - 2002 Chevy Silverado
Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
#5868 03/20/02 04:35 AM
Mike
Same block, different Heads/Intake (Jaguar Spec).
1998 SVT Contour E1, Black
2001 Honda SuperHawk VTR1000F
"I bent my Wookie"
www.mamisano.com
#5869 03/20/02 04:04 PM
The Probe GT and MX-6 had a Mazda V6 engine with timing belts.
The Contour, Mystique and Cougar have the Duratec with timing chains, edisigned by Ford of Europe with Porsche help.
Two completely different engines.
Dan B.
#5870 03/20/02 05:43 PM
Originally posted by mamisano:
[b]Demon, is it true the jag x-type nd s-type have 3L duratechs? wonder the possibilities
Mike
Same block, different Heads/Intake (Jaguar Spec).[/b]
I wonder what kind of waterpump :rolleyes:
Regards,
Kirill
98.5 Contour SE Silver Frost (powered by Duratec 2.5L)
Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i
\_ Blaupunkt ODx694
#5871 03/21/02 02:14 AM
F
F
Originally posted by Kirill:
[b]
Mike
I wonder what kind of waterpump :rolleyes: [/b]
Japenese made, like all of Fords water pumps.
98.5 CSVT
CTA open air element
Otherwise stock
