Originally posted by dbird:
..i got a 96 contour V-6, 2.5 L engine....
..it came up with the code for the egr valve..
..the V-6 engine the tube nut from the exhaust man. to the EGR valve is much bigger than 22 MM
.... i cant get my hand in there at all to measure it or use an adjustable open end wrench to get to the nut....
..also there is a pipe that comes out the EGR valve on the V-6 thats about 4 inches long-looks like a short piece of black iron pipe that goes into the EGR valve and then the EGR tube is attached to this pipe with the nut on the EGR tube
... did anyone ever take off the EGR valve on the contour V-6 engine and if so how do you do it. i dont want to break the tube..seems kinda delicate
.. the cd says to be carefull with the tube as it is not sold as a seperate part...comes with the exhaust manifold
... thanks in advance...
I am posting solely to answer your questions on removal of EGR valve and the EGR valve-to-exhaust maniold-tube.
Please note
my experience is with '97 model . I do not know if '96 is the same.
no comment.
I believe size is 1 1/8" or 28mm.
You must use an open end wrench, not an adjustable (too thick).
The "pipe" is actually attached to the nut and is part of the tube assembly. Threads are at one end of "pipe" inside EGR intake opening, nut is at firewall end.
Yes, about 5 times (its a long story -- don't ask
). Undo 2 bolts holding EGR valve to engine, remove vacuum feed (carefully, plastic tube can be brittle and prone to breaking) undo big nut and slide "pipe" along tube. Tube is not delicate. Remove EGR valve.
Tube is available from Ford w/o manifold.
You're welcome.
