I got a prob with my hvac unit, it works great but only if i put the switch at "high"....the 3 other speed does'nt work, somebody knows what to check in first step ?
mods ? Wut ! 19 inches ! My Car SOLD
i have the some exact problem..but a little vice versa, all three speeds BUT high work! maybe we both can get the problems solved here!
Teal|'95 'Tour GL|75k| 16V 2.0|Rebuilt ATX| Factory Euro Mod's (Ordered in Dec '94 From Holland)-|Larger Radiator, Oil pan, Fan, Tank..little things make a difference| Lots of mods to come....
H
H
Check FAQ section on home page.
IIRC there was a recall for this purpose. It was an extension of the warranty covering the unit for 10 years from the date of purchase.
01M07 AUG 01 Campaign - Blower Motor Switch Extended Coverage
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
N
N
It's called a resistor to the fan motor. I had the same problem too. Fixed under recall.
I'd do a search for resistor and you should see something. don't forget to search in forum archives.
You should get a recall number and you can call Ford to see if your's is covered.
