Posts: 2,263 |
well i searched and no luck, but the subject says it all...thanx in advance.
Jim Hahn 1996 T-Red Contour SE 2002 Black Mazda MP5 Latest mods: sho shop off road y-pipe
Posts: 956 |
** CT - USA **
* 96 Contour Gl 2.0 5 Speed Manual / Clarion CD Change 8" Subwoofer & Sony Amp (LOUD !!) The Cleanest !!!
* 92 Mazda Protege 5 Speed Manual / 1.8
* 94 Yamaha Virago 535 (better than Viagra !!)
Posts: 5,805 |
With dino oil I'd suggest ever 2 years, with synth every 3,but always use XR-3 Friction Mod and drain when hot....If you have a 'Bulldog MkIII' depending on use/track time etc ,change the remote filter every 6 months(the Bulldog IS the ONLY MTX75 that has a 'filter!!!! (Sorry,had to shove that one in!!!)
Posts: 3,419 |
Terry, changing my fluid every 3 years (I use Mobil 1 Synth ATF) would mean I am changing every 60k miles. With all the miles I run per year, should I change it earler? I was probably going to do it every 25k just to be on the safe side, but a standard 3 year recommendation would mean ~36k.
Posts: 101 |
If you have to think about it, then it's been too long! LOL
Changed mine at 66K, with Mobil-1 + Friction Modifier and it is MUCH smoother now. It's too easy.
Jim 98 EO CSVT #761
Posts: 7,329 |
I changed mine at 2yrs/20k
I run the "Cocktail"
It looked a little dark, but wasn't burnt. I'd rather be safe then sorry as the syncros are finicky to begin with. Cheap, easy insurance IMO.
Don't forget to flush/bleed the clutch hydraulics (and brakes for that matter)
Posts: 376 |
Is there a how to anywhere for bleeding the clutch? I never heard mention of this till today and now I've heard of it like 2 or 3 times. I've had no problems and the car has 50K on it, but I'm switching to the cocktail with Redline end of the week and just curious about doing this.
~Shawn Clone~
1999 SE Sport V6 MTX Silver frost/Midnight Blue BAT Euro Handling kit, SCA Cold Air intake, painted dash/calipers, Elky's mesh grille, bulitt fuel door,B&M shifter, ES motor mount inserts, OMP front strut tower brace, newest mod- HPP rear strut tower brace ...coming soon, Aussie Bar Possabilities in the works: Custom CAI, Polished stainless shifter cover plate
Posts: 308 |
Why does mfr say never need to replace mtx fluid?
1996 Contour GL Sport, Zetec, MTX
1995 Contour GL, Zetec, MTX
Posts: 3,636 |
Originally posted by jeffyscott: Why does mfr say never need to replace mtx fluid? Because they want you to buy a new car. They don't recommend flushing the brake fluid either, but it's a very good idea. TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 5,805 |
I strip down MTX75's every week,trust me ,regular oil change on the trans is a small price to pay...unless you want a rebuild bill from me!!!
