E
eagle98 Offline OP
E
I have a 98 Contour SE, 2.0L. Only when making right hand turns, the car will all of a sudden try to fishtail slightly back left. Sometimes it will do this several times.
The left control arm was changed (thought front bushing was possibly bad), the strut, ball joint, wheel bearing is all new. Front end-alignment has been done.
I know the car was previously whacked in the front left. What if the engine/trans was not centered properly? What if the sway bar was slight bent ? Just desperately grouping for possible answers. HELP!!!
have you checked your tire pressure/condition?
Seems that you have done all that other work, I'm sure the tires are fine..... but i had a similar type of problem in an older car, and it turned out my tire had very little air pressure, and i couldn't tell because they were 40 series tires.
Just a thought,
Jason
98 E0 SVT w/some stuff smile
J.Oetting
98 SVT Contour
http://www.envuscc.com
E
eagle98 Offline OP
E
Tirs are new. Pressures are checked and speced.
Check the sway bar for binding on the bushes..if the bar is bent it will cause the 'kick' you discribe when the tension in the bar overcomes the drag of the bush...
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Y
Y
In that case you could join the group buy for an Aussie Sway Bar! laugh
1998 black Contour SVT E0
-KKM Intake
-Magnecor 8.5 mm spark plug wires
-Bosch +4 platinum spark plugs
-B&M Short Shifter
-SPARCO front strut tower bar
-17x7 Rage 5.0's with Nitto NT450's
(215/45-17)
-24mm Aussie rear sway bar
i bet the alignment is off...weird hadling problems happen when an alignment is off
96 zetec gl.dynomax exhaust(self bent) KKM intake..Bridgestone Potenza RE-910's...other mods also
87' Ford Thunderbird..Now my daily driver ( the wife uses the contour mostly) true dual exhaust with the super mystery mod.(hey there not even there!) tinted windows and stereo upgrade. the $200 car is starting to be a great car
