Page 3 of 3 1 2 3
#579661 03/27/03 05:04 AM
No life but CEG
No life but CEG
i got an idea for the rear seat.
R.I.P: 95 Tour LX working on getting SVT Power! SELLING 3L LIM AND UIM W/ TB!!! PM ME....
#579662 06/03/03 09:52 PM
Originally posted by horseydug:
Originally posted by olekeg:
.... i cant get the middle seatbelt undone.
You have to separate at the buckle with a screwdriver.
Push seat cushion back and up should do it if your hands are at carpet level. If at top front edge then down, back and up should do it.
Do not separate it at the buckle unless you want to break it!! Just did that to mine and now i am looking at it on the underside of the buckle there is a small hole, you need to stick somthing up there and it will release the belt. You dont have to break off the plastic cover!!!
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998 WR Headers GMK CAI Blaupunkt system fiberglass tweeter pods L.E.D. tail lights in the works
#579663 06/03/03 10:40 PM
Q
Q
READ THE OWNERS MANUALS GUYS!!!! IT IS UNDER THE "SEATING " SECTION!!!!
There is a small hole you can get a paperclip in!
As far as the seat goes. Stand outside the car and pull up on the front of the rear seat near the corner on one side. It will pop, then go to the other side and do the same thing. Once you have that done push down and back on the rear of the cushion to unhook it on both sides.
You're not going to save a ton of weight doing this mod though. The seat is incredibly light. You're going to get a ton of road noise from this mod also.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels 1/4 mile - 15.201@89.4mph
#579664 06/04/03 01:53 AM
What exactly is under the seats??
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
#579665 06/04/03 02:01 AM
um metal?!?!?
Formaly FLCEGkid Chris Bertrand 1995 Ford Contour Gl 2.5 V6 MTX FOR SALE! Somebody please buy my Fiberglas hood!!
#579666 06/04/03 07:49 AM
Q
Q
Easy access to the fuel pump with some tin snips. You can gain access to the connectors without tin snips since they are just covered by a rubber gramut. But if you have a bad fuel pump and want to change it out then you have to enlarge the prexisting hole.
Other then that and just wanting to take the back seat out for weight I see no other purpose. Unless you're wanting to make your car noisy inside.
#579667 06/05/03 02:58 PM
"You're not going to save a ton of weight doing this mod though. The seat is incredibly light. You're going to get a ton of road noise from this mod also."
Took seat out to put in system. i am going for a professional look not wires everywere.
Page 3 of 3 1 2 3
