Posts: 2,299 |
water wetter is some super neato stuff. I'm not sure what is in it to give its properties. But basically what it does is lower or and even virtaually eliminate the water's surface tension which greatly reduces the thickness of the boundry layer flow. The surface tension of water or even anti-freeze coolant mix causes the coolant to leave voids in areas where it turns sharp corners inside the water jackets. The surface tension (what makes water bead up) acts all the time, what happens is when the water flows ocer a surface there is a certain thickness of water that "clings" to the surface and becasue of this clinging the water moves very slowly. This boundry layer is also not easily disturbed. SO basically the coolant sticks to the insides of the engine and can casue what is referred to as boundry layer boiling where the coolant can boil in an area about 1/8 to 1/16 inch deep in the hot areas of the engine. In extreme conditions these local boiling spots can boil so violently that they actually turn to a froth almost eliminating heat transfer to the coolant through conduction and now the area is cooling mostly by convection. The boundry layer phenomenom also exists inside the radiator where due to the boundry layer flow the majority of the flow of hot coolant is not in direct contact with the tubes of the radiator, instead the hot water must transfer its heat to the surface of the tube through this thin boundry layer flow which is terribly inefficent.
Water Wetter reduces this tendency. Addition of water wetter to the coolant can increase the capacity of the cooling system by up to 25% by improving heat transfer.
Boundry layer flow is both a blessing and a curse depending on the environment. In the cooling system of an engine it is a curse, but the boundry layer flow can also be used to insulate critical components from heat. Boundry layer flow is utilized inside turbine engine turbine sections. Here boundry layer air flows are used to sourround the turbine and turbine inlet vanes. This layer of relatively cool air protects the vanes from the exhasut gasses that are hotter than the melting point of the material the vanes are made of.
I feel sorry for the people who don't drink. When they wake up in the morning, thats the best they're going to feel all day - former President Lyndon B. Johnson
Posts: 2,299 |
Originally posted by JSmith: Red Line's water wetter
got some.
I'm gonna wait for the system to cool down before I add it so I don't end up taking a hot orange shower.
Smurfette
Smurfette
Posts: 8,770 |
where did you end up finding it?
Kim
1995 Contour GL
Needs less "needs more"
Posts: 1,272 |
Ummm.....yah.....thanks J, I think.....  Yeah, where did you end up getting it?? I was going to take a run out to Pep boys tonight and pick some up (along with oil change products)
A1C Hodges, Christopher Active Duty USAF Sheppard AFB Texas;Westover ARB Chicopee, MA
NECEG "Troll"
formerly owned 2000 SVT Contour, with all kinds of goodies;)
Posts: 4,639 |
jay, i got the redline water wetter and fuel injection cleaner at the waterbury pepboys. is there one in your area.
Hugo AIM:omegazodiac
Posts: 2,299 |
nearest pep boys I know of near me is West Springfield. Far away.
I found it at a local speed shop. National Speed Center. The guy there is very knowledgable and if he doesn't have it in the store he can get just about anything you want.
I'll have to talk to him about getting stuff for the contour.
Posts: 431 |
2 questions as this is new to me:
- with the SC, I want to lower engine temps (especially in the summer) so it appears I should go get some quick, eh?
- how does removing the engine headliner increase engine temps?
d
For Sale: 1998.5 Silver Frost SVT.
Vortech supercharger, ShoShop Y Pipe, Borla catback, DMD, Spec Stage II clutch, Quaife LSD, B+M shifter, Ground control coilovers, Koni struts and much more.
see classifieds....
Smurfette
Smurfette
Posts: 8,770 |
Do you know if Corey already put water wetter in?
as far as the headliner issue, I think elky is just a freak of nature. But seriously, I don't think CobraR experienced an increase in temps after he took his liner off. There are a couple others in NE who have also removed theirs, so perhaps they could pipe in with their experiences as well.
Kim
1995 Contour GL
Posts: 2,299 |
it makes sense that the hood liner would increase engine compartment temperatures. The liner is a layer of insulation over the metal hood that could otherwise be conducting heat away from under the hood. The heat would then be removed from the hood by the air flowing over the top of the hood while you drive. Removing the liner gives you a coninent space to put stickers and other effects.
Negative effects of removing the hood liner are: the engine will cool off faster especially in cold weather after shutting the engine off. In case of an engine fire there is a higher chance of the hood suffering heat damage to the paint from the lack of insulation on the bottom of the hood. There will no longer be a convinent home for little critters like mice to live in the small spaces between the liner and the hood. In the case of an oil leak the hood liner can become oil soaked making it a fire hazard.
I'm sure I could think of more.
Posts: 505 |
Originally posted by frenchblueC2: Originally posted by daniels_scsvt: 2 questions as this is new to me:
My car runs slightly cooler, by the guage, than before I took the liner off. I can see where it would make sense for the engine to cool off quicker in the Winter. But the issue where more heat can radiate into the engine bay, in the Summer, I can't see as holding true.
Example: people are a source of heat (like a car engine). You're laying on the beach in the sun. The sun makes you hot. Then you pull a thermal blanket over you. Are you hotter now? You betcha you are.
The best thing would probably to have it out in the Summer and in for the Winter.
Just my $.02
