Posts: 460 |
Thanks guys! It doesn't look or sound all that hard. It looks tedious as hell though. I have had my TB off already and hae ripped my entire intake apart countless times. I can do this. I will order the gaskets and prepare to carpool with my other half for a week or so while my car is down. She will be sooo happy. :rolleyes:
Po-Jay
Ghetto Mods Galore! Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap- Blood,Sweat,Tears Do I hear the Fat Lady singing? 98 E0 Silver Frost (Is there any other color?) 172HP 149TQ W/Bad A/F Mix
Posts: 8 |
I've heard a lot of stories about these engines hitting a wall around 4 to 5 thousand, and it's usually turned out to be a fuel pump problem, see if it only happens with fuel level under 1/4 tank. If that's the case, your fuel pump is getting ready to go.
Posts: 8 |
Posts: 460 |
I never let my fuel level go below 1/2 tank. I have heard too many people complaining of tank sediment being sucked up.
Po-Jay
Posts: 2,523 |
Do I need to pencil you in for a few hours? I've been thinking it was time for a good break-down, cleaning and gasket-replacing party on the Zetec for a while - maybe I should order a few things as well... I'll even see what info my magic DVD has to offer.
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 101 |
pollo_loco69...How many miles were on that car when you cleaned the LIM? Just cleaned mine at 66K and no where near as bad. Just used some carb cleaner and the pressure alone cleaned it!
Jim 98 EO CSVT #761
Posts: 1,041 |
Great pictures Crazy Chicken! Mine looked exactly like yours, cleaned mine a bit over 60,000. Never removed the LIM but did a excellent cleaning if i may say so. Use a little Brake Cleaner for the Hard Spots. Takes the crap out faster. Oh Yeah Clean that Throttle Body Good also. Check out my Homepage in the Mod sections for a clean Intake.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 19 |
Do the part numbers for the gaskets listed in the FAQ good for 98- Contours? The FAQ says 95-97 only...
Posts: 9,178 |
You can order them from www.fordpartsonline.com go through and pick the year, ford, contour, mechanical, Fuel System, Fuel Induction, Intake, Manifold Gasket, Contour, Mystique, 2.5L. It lists them there. You need one upper and two lower. HTH
Posts: 9,178 |
Originally posted by Speed Demons: Great pictures Crazy Chicken! Mine looked exactly like yours, cleaned mine a bit over 60,000. Never removed the LIM but did a excellent cleaning if i may say so. Use a little Brake Cleaner for the Hard Spots. Takes the crap out faster. Oh Yeah Clean that Throttle Body Good also.
Check out my Homepage in the Mod sections for a clean Intake.Thanks.  It is Horse(Scot)'s car. He had 58-59,000 on it. We are tearing into it again tomorrow. Those pics were taken about 2-3 weeks ago and I will get some new ones that show how clean things are now.
